Crespro wrote:
4x4ord wrote:
The difference in price between a diesel srw and a 7.3 litre gasoline powered dually is about $6500. You’d likely get $5k of that back 12 years down the road. For a 15k fiver I think you’d be much happier with a SRW diesel than a dual wheeled gasser.
Diesel Price on same F-350 with $3K discount is about $64K or $10K more. I agree the diesel is a great engine (had a 400 ISL in my Monaco), but the 7.3 gas is a good option up to 16K. If you plan to tow over 16K, you clearly should have a diesel.
Base MSRPS1 $46,305 Total of OptionsS4 $19,385 Destination ChargesS17 $1,695 Total MSRPS16 $67,385
2020 Ford Super Duty F-350 XLT Crew Cab®, 8’ Box, 6.7L Power Stroke® V8 Turbo Diesel Engine, TorqShift® 10-speed Automatic Transmission, 4.10 Limited Slip Axle Ratio, 4X2, DRW$46,305
Iconic Silver$0 Power Stroke® V8 Turbo Diesel Engine 4X2 TorqShift® 10-speed Automatic Transmission with Selectable Drive Modes 4.10 Limited Slip Axle Ratio
Ultimate Trailer Tow Camera System with Pro Trailer Backup Assist™$1,600
XLT Premium Package $3,025 11,400 (SRW)/13,000 (DRW Only) GVWR Package $0
17" Forged Polished Aluminum Wheels with Bright Hub Cover and Center Ornament (DRW)$600
Tailgate Step with Tailgate Assist $375 Bedliner – Tough Bed® Spray-in$595 Rear Window – Defrost with Privacy Glass $60
5th-Wheel/Gooseneck Hitch Prep Package $500 BoxLink™$0 Hitch Kit – 5th Wheel, 27.5K$1,495 PowerScope® Telescoping Trailer Tow Mirrors $280
6-inch Angular Chrome Running Boards $0 LT245/75Rx17E BSW A/S Tires$0
The diesel is about a 10k option. Duals are about 1300 and the 7.3 is about a 1700 option. So the Msrp of a SRW diesel will be about 7k more than the MSRP of the 7.3 dually. You should be able to negotiate at least 10% off MSRP which puts the difference at about $6300.
