blaczero wrote:
Hey guys, I have been looking at the F350 for a 5th wheel I will be buying and I am confused about SRW / DRW.
According to the towing weight / GCWR, there is only about 500lb difference between SRW/DRW.
Why would you go dualie then? I figured SRW with 6.7' bed would be better driving w/o the 5th attached, better to get in and out of parking lots etc...
What am I missing?
Well you were likely looking at the wrong chart, as a DRW with not only have a greater tow rating, but more importantly a much higher Payload capacity.
It matters what you are looking at towing, most feel the line to go DRW is between 14,000# and 16,000# 5er GVWR
Even a SRW has a towing capacity of 20,000#+/-, but don't have the payload to carry it. Depending on what you carry in your TV, personally I carry a bit. we have a 5er with a 2,800# pin, had I gone with a SRW i would have likely been within about 200# of GVWR. We went with a DRW and have an extra 1,200# or so of excess payload.
The other thing to keep in mind is Payload doesn't equal how much pin weight you can carry. Before you can talk pin weight you need to need to subtract everything you have added to the truck (TV) after purchase. Actually a much easier and more accurate method is to get every thing added to the TV, passengers, tools, hitch, firewood, and fuel. Then head to the scales and weigh the TV. Best to get separate axle weights. Nowadays with a SRW you might have more total payload available than you have available rear axle payload available.
As to wheel base and bed length, I much prefer an 8' bed for towing a 5er, no issues with 5er to cab contact, in addition a long wheel base gives a smoother ride both loaded and unloaded.
We full time and our 2016 Ram Laramie 3500 DRW CC LB is our daily driver, there are a few drive thru I will not that it thru, but other than that no real issues.
Last question what are you looking at towing with it.
