pbar34 wrote:
Hi Chris,
I agree with most of your sentiment about ST tires and that is why I upgraded to 16" Duravis R250 tires from my 15" ST. I have been towing for a while and own several trailers (11 axles of ST tires, total), so I've seen my share of ST tire failures and have been a student on this forum and other forums of other tire failure stories. My experience is that the ST tire lamination process is unreliable for our heavy trailers.
This said, your exclamatory comment to me was that I must not have compared the R250 specs to the ST tires. Since I'm talking about sidewall stiffness here, my question to you remains what data do you have, which you think I didn't compare, that shows the R250 sidewalls are stiffer than an ST, Load E, 10 ply tire? I'm not doubting but asking for the data/info since every manufacturer's website that I have visited, including for LT tires, cite the stiffer sidewalls of the ST tire, when compared to an LT or passenger tire.
mrw8i - Not sure who your question or comment is directed but if it is to me, yes I do have three engineering degrees (not up to PhD just MSME) with a heavy emphasis on materials science in my engineering career. Doesn't make me a tire expert by any means! but I do understand mechanics and physics pretty well. For technical stuff, I typically do not put a lot of faith in much of what I read in a forum or on a manufacturer's website unless I can validate the info/data from other sources.
Thanks,
Phil
No not directed at you. At tire store workers in general. I don't trust everything they say, as they only know the marketing literature or what they are told by others they work with, if that.
My first and only ST blow out was after 100 miles. Hot desert driving, no more than 60 mph if that during that 100 mile drive. No manufacturing defect. Just poor design, namely the very thin sidewall on ST tires. 2 lane highway where the speed limit is 65mph, and trailers 55mph. Left turn approaching with a line of traffic behind me. So I need to pull into the left turn lane, come to a stop and then turn. The center median before the left turn lane is just painted lines to mark it. With all the traffic behind me and high speed I cheat a little when I move into the left turn lane by moving into the center median area just before the left turn lane, so the traffic behind me does not have to slow down as they pass me in the lane to the right. The median area not being an area where cars are normally driven so there is a small amount of debris, small rocks, etc. As I pull into that area, doing about 50mph a tire on the trailer blows. Turns by inspection by me and the tire dealer I went to 50 miles later it looks like something hit the sidewall puncturing the sidewall and the tire blew. The guess is a small rock got run over by a tire on the other side and flew across hitting the ST tire.
Since then I make sure my ST tires never run on the shoulder or in an area where traffic does not normally run at high speed.
I doubt that tire would have been punctured or blown if it had thicker sidewalls. That was my first time I actually saw how thin ST sidewalls were. I'm no engineer, but it just looks like a cheap tire, that could never be used on a car or truck but works okay with trailers, under the right circumstances. An ST tire seems like a design that is inexpensive, cheap to make, works for many trailer applications, is better than passenger car tires for trailers - but I don't think it is always the right tire for a trailer, especially heavy trailers that do a lot of highway miles.
Never seen a U-Haul trailer with ST tires.
