SDcampowneroper
Jan 18, 2021Explorer
Adjust electric drum brakes every. 2k miles, even if the mfgr says they are self adjusting. We have poor experience with self adjusters
. Have a helper apply the brakes in the tow, its better than pulling the pin on the breakaway switch. use a V/A meter to insure application at each wheel. Volts and amps. Undersize or poor connections in wiring will still show voltage but not the amperage to fully engage the brake.
12 v dc needs a fat wire with strong connections to carry the current to those magnets.
Simplest method to verify brakes are working is to use a compass. with the brakes engaged, the north needle will lock onto that wheels magnet.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
