tjohnsen's avatar
tjohnsen
e track pulled up
I recently got a new to me Yamaha Rhino. Bought it specifically because it was short enough to fit in my 10 foot garage of my 2008 Raptor 299MP. In my first trip with the Rhino I made it to our destination just fine, but when I got home I saw that several feet of track had been pulled out of the garage floor. Fortunately, there was no interior damage to the trailer from the Rhino bouncing around.
I had been using long screws into the floor and they failed. Has anyone used nuts, washers, and bolts? I know these would hold but I would have to go underneath and pull the undercarriage screening off the trailer. I would imagine I could staple it back on easy enough. Am I correct? Would this be a good, low cost, solution to the track coming loose?
Thanks!
  • Question for you are you tying down the rhino itself or only the wheels?
    I was tying off of the roll cage.
  • I replaced the tie-downs in my rig last year with larger D-rings. I through-bolted each one of them into the frame of the rig. Although it took some thorough measuring, it was worth the effort.
    In addition to securing the rings or e-track I would recommend cross-strapping the toy in place. This will allow a little more flex in the straps.
    Good luck
    Bill
  • If you tie off to the roll cage or frame, a big bump in the road will cause the suspension to compress, loosening the straps which will act like a Jerk strap when the Rhino rebounds.
    If you tie down the tires or attach to the suspension close to the wheels, this is unlikely to happen. In my Toy Hauler or in my box trailer, I cross tie them diagonally...my e-track is attached with 1-1/4" long # 14 SS screws in every other hole - no problems so far!
  • The protective underbelly cover is attached with screws into the frame of the 299mp you cannot staple it back on. Also under the front part of the garage floor is the fresh water holding tank and under the middle part of the floor is the 30 gal. Gas tank. You really should remove the cover to make sure you don't damage either of these. You don't have to remove the entire cover....you can remove the screws from part of it and cut the cover to move it out of the way. They make a wide tape especially for taping the cover back together. You can buy the tape at your rv dealer.
    Thanks!
    I through bolted mine @ every cross member and used screws in between. My Prowler came loose and punched through the maple door going into the living quarters in a prior toy hauler so when I traded trailers I bolted it @ the cross members with carriage bolts & lock washers.
