Mamacast's avatar
Mamacast
Easiest 5th hitch to connect for 1 smaller woman?
I am wondering if there is a difference in difficulty for connecting your FW depending on the hitch you have? We are getting our first FW and will be purchasing the hitch at the dealer. They sell Pullrite but I am wondering how the TrailerSaver Air-Rides compare in terms of ease of connecting? Thanks for any replies. If it matters it is an 8 ft bed.
  • Everyone is going to say their hitch is the best. But really they are all essentially the same as far as ease of hitching and unhitching. Except for the Anderson that uses a ball mount. Then you have to be a little more precise in positioning the hitch ball under the trailer receiver. On a standard 5th wheel hitch you can be off an inch or more to the side and it will self align as you back under it.
    I had a Pullrite Super 5th in my previous truck and it is a very good hitch. I would have bought another for my current truck but at the time they did not have one to fit the Ford factory hitch prep.
    Have no experience with the Trail Saver.
  • Is the intention to remove the hitch between outings?
    If that is the case then the Anderson Ultimate or something along those lines would be the LIGHTEST and easiest to remove from the truck. (I would get the rail version if it was me).
    If not, like others have said there really isn't anything physically demanding on any hitch.
  • You're not talking about the Superglide are you? If so, you don't need it with an 8' bed. In my opinion, my B&W Patriot is much better than my Reese was. It doesn't matter if you're a woman or not, you can operate any hitch out there.
  • I have an older Reece 16K hitch, and I don't think there could be an easier hitch to operate. As long as I have the jaws closed, the kingpin at the right height in relation to the hitch and get the kingpin and the hitch in alignment, all I have to do is back the truck. The jaws spread open as the kingpin slides in, and then they close around it. I then do a "pull test" followed by a visual inspection to make sure the jaws are closed around the kingpin correctly.
