Roger10378
Jul 20, 2019Explorer II
I have to disagree with the last part. I have never seen a brake that you have to hold the lever off the star wheel to tighten the brake adjustment. You only need to hold it to slacken the adjustment. The reason for the two holes is that they use the same backing plate stamping for both the right and left brake, so the star wheel will be behind the one hole on the right and the other hole on the left.
About Fifth Wheel Group
