time2roll
Jul 24, 2019Nomad
Rwake901 wrote:Not if the braking performance is poor. Hence the need for initial adjustment. Have you manually applied the trailer brakes at full power? Maybe the controller needs adjustment. Virtually new should be working but no guaranty.
Looked at a different wheel tonight and found the adjusting wheel. It’s mostly hidden behind a piece of metal that I’m assuming is the self adjuster. Which means that I shouldn’t have to adjust them because they will eventually adjust themselves. Right?
About Fifth Wheel Group
