Rwake901
Jul 25, 2019Explorer
time2roll wrote:Rwake901 wrote:Not if the braking performance is poor. Hence the need for initial adjustment. Have you manually applied the trailer brakes at full power? Maybe the controller needs adjustment. Virtually new should be working but no guaranty.
Looked at a different wheel tonight and found the adjusting wheel. It’s mostly hidden behind a piece of metal that I’m assuming is the self adjuster. Which means that I shouldn’t have to adjust them because they will eventually adjust themselves. Right?
I will adjust them this weekend. I have the brake controller turned up as high as it will go.
About Fifth Wheel Group
