Socalou's avatar
Socalou
electric bunk beds
Hi I have WW toy hauler I am having issues with the electric bunk beds a fuse blew out so I replaced it when I insert the new fuse the bunk bed motor turns on and keeps running. If I push the switch it will go down but not up once I release the the switch you can hear the motor running anyone have any Ideas on what is causing this?
  • Thanks guys I will replace it next week an see if that is the problem I will report back.
  • I agree with bad switch--probably what blew the fuse in the first place.
  • Yes the fuse was replaced with the same size, the tracks look clean the chain inside the track is lubricated everything looks clean.
  • Are the tracks clean & lubricated? Is the fuse the right size?
