DRVMN's avatar
DRVMN
Electric over hydraulic brakes
Just bought a 2013 Elite Suites 5th wheel that has electric over hydraulic disc braking system. Pulling it with a 2017 F350 Super Duty.
When applying brakes with the hand control at full power I am getting very little braking.
Does anyone know if there is any power adjustment on the brake actuator that is located on the RV? Or any ideas how to increase the braking power applied to the trailer brakes? As I mentioned earlier the power setting on the brakes controller in the truck is set at max (10)
  • The breakaway test is a great idea. The unit has only been pulled 500 miles when new and in storage the remainder of the time. All disc's and rotors are in great shape and move freely
  • The truck setting is a good point - I will check that out and hopefully thats the issue.
    I have bled plenty of brake systems in the past but never a electric over hydraulic one. I will have to study up on that before starting.
    Thanks
  • Easy check to see if it's truck or a trailer problem is to pull the break away switch and see if the trailer brakes lockup.
    Denny
  • you should be able to lock up all wheels. something is very wrong. guessing from here is just that, a guess. I would start by checking fluid in pump and then bleeding brakes. Is the pump running fully or is it running on lower voltage than it should? Could have undersized wire and a big voltage drop? Controller could be bad. How about going to a deserted place and have someone in the bed pull the breakaway switch at a low speed and see if tires lock up. Are pads free and able to move properly? Are pads good or totally worn? All good questions with answers only available from you.
  • Our 2016 has setting for Elec and Elec over Hyd. and low med high braking effort as well as the 0-10
    If you have 3 axles with Dexter disc (large pistons) brakes a second or larger pump maybe needed.
    Also check to see if the brake were bled properly.
