broark01's avatar
broark01
Explorer II
Apr 25, 2016
Electric Trailer Brakes and Gain Caused Wear
In 2012 I replaced all components of the electric brakes on the 5th wheel, from backing plate out and all bearing components (not hub). Last year (2015) I started getting "trailer wiring fault" intermittently then constantly on the last long trip home with complete trailer brake failure during these outages.
Prior to winter, I replaced the easy stuff like the break away switch and the 7-way harness and all of their associated connectors. No luck.
A couple of things I considered over the winter:
1) Was running the brakes at a gain of 10 (max)
2) If the gain is making the magnet pull harder against the hub to provide more force to the brakes, then it is probably causing more wear on the magnets, hub and the pads.
Spent 8 hours this last weekend replacing magnets, repacking bearings and putting in new seals on all 4 wheels. Brake shoes still have another season or 2 left but I will need to replace (or refinish) the side of the hubs when I replace the pads.
After the magnet replacement, no "trailer wiring faults" yet and the magnets did look pretty bad.
I have reduced the gain to 7.5 but am not very happy with the stopping power from the trailer. Anyone else have similar observations or thoughts on this subject (yes I know, get disc brakes).
