3oaks
Apr 25, 2016Explorer
A couple of things I considered over the winter:Perfectly normal and to be expected. The higher the gain, the higher the wear.
1) Was running the brakes at a gain of 10 (max)
2) If the gain is making the magnet pull harder against the hub to provide more force to the brakes, then it is probably causing more wear on the magnets, hub and the pads.
I find it much cheaper to replace the entire brake assemblies rather than individual components.
I purchase everything through: etrailer
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 16, 2026
