decal215's avatar
decal215
electrical / lights
I recently purchased a 2004 komfort 5th wheel trailer. the lights only work when I'm connected to 110. When i disconnect from 110, the lights won't work off the battery.
Any ideas?
  • Old Duck wrote:
    I've got an 05 Komfort, my battery disconnect is right by the kitchen sink. Hope it's your problem!
    This thread had 9 posts in it before you rerplied. It wasnt like it was 9 pages. 9 posts :R:h
  • I've got an 05 Komfort, my battery disconnect is right by the kitchen sink. Hope it's your problem!
  • You folks were right. I replaced the battery disconnect switch and everything works.
    Thanks
  • Are they 12v. lights? Does anything else that runs on 12v. work? Sounds like either the battery is dead, missing or not wired up to the system correctly.
  • Look in compartment where battery is.....follow positive cable to the next item in line....a switch. It should be in ON position.
    No switch.......then check the battery voltage. If voltage is low then recharge/get it load tested/get a new battery.
    THEN you need to check converter output....it should keep battery charged.
    Hopefully you find a switch OFF and your battery is OK
  • pianotuna wrote:
    Hi decal215,
    No it separates the house batteries from the power distribution center. It must be on to allow the battery bank to supply power to the trailer.
    ....and if that doesnt work you have a bad circuit breaker.
  • Hi decal215,
  • the batteries are new
    a battery disconnect switch. separates the trailer batteries from the truck?
  • Could be that your battery is shot. With a 2004 this is no surprise.
    WoodGlue
  • Hi,
    Is there a battery disconnect switch?
    Are the batteries charging?
