time2roll
Nov 15, 2015Nomad
All RV systems should operate fine from 10.0 volts to 15.0 volts.
Converter output between 13.2 and 14.6 volts is common and normal.
I might be more concerned about the fluctuation more than the actual voltage. Voltage should be very steady in general conditions.
Seems odd for a new motor to fail like that.... if it was the right motor.
I think you mean the two 12v batteries are in parallel.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
