YC_1
Nov 16, 2015Nomad
SkiSmuggs wrote:
I have two GC2 6 volts in series for 12v. When the furnace in running without being connected to shore power, my voltage reading often drops below 12v until the furnace shuts down, then returns to the original charge which, when full, is 12.7-8. You can only get accurate battery voltage readings with no charging or no load for a period of time.
I would check the specific gravity. The heater draws 6-8 amps and should not pull the voltage down so far.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
