Robert6401
Oct 18, 2014Explorer
Electrical issue, exploded battery
I need some help please. Last week I was trying to open up the slides on battery power and connected to the truck. After about 3 seconds, the motor shut off and I lost all 12v power to the RV. I was able to connect to 110v AC, and everything worked except the slide switch inside the RV. I used the slide switch at the motor to open them up. Everything else seemed to work normally on AC power, but I never heard the inverter fan running.
I didn't mess with it again until today. The first thing I did was check the battery and I noticed that the casing had bursted open and the caps where you put water on the top had blown off. There was also a good bit of corrosion on the battery post connection to the positive line for the RV.
I'm not the most knowledgeable when it comes to these electrical systems, but I'm fairly mechanically inclined and am not afraid to get my hands dirty trying to figure this out.
Any advice on where to go from here? Should I just replace the battery and see what happens?
