Trailblzrprincs's avatar
Nov 09, 2017
Electrical issues
My 5th wheel (2010 Komfort Trailblazer) won't allow me to run certain electricity components.
For example I will have the propane heat running and if i switch one light on the light and the furnace will start to flicker in and out after about 20 seconds. If i don't have the furnace running i can turn on two or three lights before they begin to dim in and out. It sounds not good. Running items plugged in does not seem to affect anything.
I have tested the volts on my battery they are fine. I have tested the volts on my converter they are 13.6 until i turn too much on then they go down 1 or 2. I have checked my fuses.
Could this mean i need to replace my converter? It is the WFCO Power Center Model WF-8955PEC. Would having it plugged in to 50 amp service affect anything?
Any thoughts are greatly appreciated, thanks.
  • Thank you all so much for your input!! Very appreciated. I decided to just order and install a new converter and everything works now!
  • You need to check voltage at the furnace with it running and when the lights start flickering and check at the convertor under the same conditions. I would bet you have a loose wire. And it could be anywhere. My lights started blinkling and after a couple days they finally quit. Then I was able to find the trouble. A undersized wirenut had fallen off. Took a lot of looking. I would not condem the convertor just yet.
  • I agree with ScottG - the dimming (pulsing)of lights was the sign when our WFCO converter died. On mine, it was pretty obvious after I took some measurements. I love my PD with the charge wizard.
    Good Luck.
  • The rhythmic dimming of the lights is a classic sign of a converter dying.
    I would simply measure the voltage at the converter and if its voltage sags with the dimming, it's toast.
  • Check on your converter right on the positive and negative output. If the voltage stays up there, but drops at the battery terminals, you have a loose wire between the two. In my case, it was the main negative wire on the negative terminal strip on the converter.
    The voltage gets drawn down by a loose connection, it makes it seem just like a load.
    Try connecting a jumper lead to your battery negative, then to the negative strip on the converter. If that fixes it, is is the negative wire. If not, try connecting a jumper lead to your battery positive, then to the positive strip on the converter. If that fixes it, it is the positive wire.
