ScottG
Jul 10, 2013Nomad
Swamp Man wrote:
If you have a twenty amp outlet, I would use a cord rated for 20 amps. Use of a smaller (less amp rated cord) is asking for trouble. The NEC (National Electrical Code) does not allow you to use wire related for less amps than the breaker it is attached to. If the installer used a 20 amp outlet, there is a reason.
That code does not apply to the cord that connects to the outlet. It's for the wiring between the breaker and an appliance or outlet.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
