jmsokol wrote:
itsabouttime wrote:
A current as low as fifteen to 25 milliamps is enough to kill and you can get that from far less than 60 volts if you are in the water. You did good in finding and fixing the trouble. From time to time any of us has to discover such a problem the hard way and sometimes it's a wonder we live as old as we do.
Yup... And if you consider that the human body with wet hands can have a resistance as low as 1,000 ohms, then as little as 30 volts AC will induce 30 mA of current across your chest cavity. That's almost 100% fatal from atrial fibrillation. Once you hit about 20 mA of current, it's nearly impossible to let go of an energized conductor.
Never accept getting shocked from an RV. It's dangerous and you might not be so lucky the next time.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Your calculations are correct but it is Ventricular fibrillation that it causes. Atrial fib is rarely fatal unless it throws a clot. As an aside, Mike, I'd like to thank you for all the info you have bestowed on us over the years about RV electrical safety.
