RAINEYTXX
Jul 11, 2014Explorer
Your DRV, like ours, probably has a remote that has key fob with a panic function that will flash the lights that is hooked up to a module in the coat closet by the front door. We had some issues when ours was new and have not used it. You can probably unplug the module--its called the "wow" module to stop the flashing if you do not have the remote available. Hope that helps.
It also controls the scare lights, slides, awning etc.
Hope that helps!
Hope that helps!
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
