- JIMNLINExplorer III
davonelson wrote:
I need to repair my 10 year old Fifth Wheel roof and saw an ad for SuperFlex Roof Coating from Camping World. Is this a practical fix?
Depends on what the repair job is.
A rip or tear in the fabric ??
Removing old caulk and adding new caulk ??
Is the old fabric stained black and you want it back to a white ??
Is the roof leaking in one spot ??
All of the above ??
Makes a difference in how the repair can be best fixed.
And keep in mind if you may sell the unit don't add anything up there that would kill the resale value. - WTP-GCExplorerThe question is whether or not your roof requires "repair" or "maintenance". The product mentioned by the OP is intended for maintenance.
- DanNJaniceExplorerThere is a guy over on the Jayco forum that just had his entire roof spray coated. He had it done by Flex Armor, I think. They have a shop in Florida if I remember correctly. He seems real happy with their work.
Here is the link:
Linky - wrgrs50sExplorerHow long is the warranty on superflex? It may only be good for a short term fix.
- mtofell1ExplorerI had a repair done once and also know quite a bit about these roofs from my work. I'd never attempt a repair myself. The guy that fixed mine talked to me a lot about them and said the key to a good fix is surface prep, using the right materials (glues, bonding agents, etc.) and just knowing what you are doing.
I do Home Inspections for work and several times have seen installations fail by the materials peeling up at joints and overlaps. My fix really wasn't that expensive either.
About Fifth Wheel Group
