Baja_Man
Oct 10, 2015Explorer
Since I currently have no leaks, I have decided to perform the following maintenance and repairs. Question: When using self-leveling Dicor to cover cracks in current Dicor caulking, does this older stuff have to be removed before new caulk is added?
Does my process sound correct?
1. Eternabond tape all around the edges of the metal panels (panels appear to be previous owner's repair).
2. Remove plexiglass over shower and replace with a skylight. Use butyl tape between skylight and rubber roof. Screw skylight down to roof. Apply Dicor over all edges of skylight, covering all screws.
3. Apply Dicor over all existing areas of caulk (vents, AC, etc) that are cracked.
Thanks
Thanks
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
