djgodden
Mar 18, 2016Explorer
I have a 2012 Ram Laramie Longhorn short-bed crew cab w/6.7 turbo diesel HO (350HP/800lbs torque) towing a 29ft Montana and use an Edge Insight to monitor a whole range of temps and pressures. Turbo timer idles until PTEGE 350F. Never put in the pre-turbo sensor for fears of the pyro failing and losing a turbine because of it. It does in fact happen. Post turbine temps have never exceeded 950F and if I get at all concerned I downshift to keep the engine in it's optimum power range ~1,900 RPM. That simple downshift sees temps drop by 200-300 degrees. IMHO, if you're RVing you aren't in such a hurry to get anywhere that warrants risking an engine/turbine.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
