pianotuna
Feb 13, 2018Nomad III
Batteries are often in unheated areas. That means the effective amp-hour rating is lowered. The heater fan on a duty cycle of 50% on my rv uses about 4 amps per hour. So running it for ten hours consumes 40 amp-hours.
There has to be a way to recharge the bank.
LowRyter wrote:
doesn't the heat run from the propane?
the batteries just run the fan. 40 degrees? Gees you should be fine for several days.
My guess you'll run out of propane first.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
