jefffoxsr
Jul 02, 2013Explorer
external wastegate for drianing tanks
What is the part called that can hook to the tank drain opening cap area that will serve the purpose of being an external wastegate?
The gate to the black tank seal isn't working so when I take the cap off I get a gallon of fecal matter on the ground. I had it at the dealer and they said the seal is fine. Wrong.
A friend said that I can buy an external wastegate that will mount where the outer drain cap is mounted right now. Then I can prevent the spillage. I need to know what this product is called so I can buy it. I have tried searches and cannot figure it out.
Thank you.
Thank you.
