plasencia87 wrote:
I replaced all tires with e rated tires. The spec on the trailer says the axles are rated at 4400lb when I called the rv shop they said there dosent exisist axles at that rating. I found a shop close to me that said they can beef up the frame and axles to achieve a higher cargo weight. Just wondering if anyone had seen this done before. I'm worried about going down the free way and having a catastrophic failure and hurting someone
Your RV shop is mistaken about the 4400 lb. axles. They are readily available.
http://kraftsmantrailers.com/parts-store/axles/4400-lb-axle-assemblies
