I'm sure I'm not the first to ask this question but I couldn't find any threads that address it. I have EZ-lube axles on my Arctic Fox 5'er. Is it safe to simply grease the bearings frequently with a...
I used them for several years making sure I greased them exactly as the procedure describes. Then one year I did a thorough inspection and found that two out of four of them had leaked grease past the seals. Reading different forums, I found this to be a common result of using the EZ lubes. Never again.
