I'm sure I'm not the first to ask this question but I couldn't find any threads that address it. I have EZ-lube axles on my Arctic Fox 5'er. Is it safe to simply grease the bearings frequently with a...
Been there, done that... just a matter of time before the seal fails and you grease the brakes... Forcing grease thru the back bearing, filling the hub cavity, and then forcing it thru the front bearing is asking a lot of a grease seal... I have read (no article to quote) that an empty hub cavity can help get rid of some of the heat generated by braking. Good luck.
