jgrimesExplorerJun 26, 2016EZ lube hubsI have read the post regarding hand packing the bearing versus using a grease gun to insert grease. That's NOT what my question involves. I visited my local auto parts store and with their recommendat...Show More
LearjetExplorerJun 30, 2016The zerts on the EZ lube hub do not rotate with the wheels. The zert is in the axle, which is fixed. If they popped off, it was from the pressure.
Related ContentEZ Lube axles/hubsDexter EZ LubePacking ez lube bearingsEZ Lube/Ultra LubeEZ Lube bearings
