Daniel97
Nov 25, 2015Explorer
f250 or f350?
After for lurking around for a while, I may have decided to pull the trigger. I am looking to buy a 2016 Dutchmen Denali 307RLS. I can tow with the F250 without being over weight (on the higher side, ...
CarlT100 wrote:valhalla360 wrote:
If it's a single rear wheel F350, I would go for that.
Unless you do a lot of off roading (for which an F250 or F350 is a horrible option anyway), not much benefit in going 4x4. Realistically, a 4x2 with limited slip and a 5th wheel on the back will have a ton of traction.
I have ti disagree. I have had one 4X2 F250 and three 4X4 F350's. I will not go back to a 4X2. I don't use the 4 wheel drive often; but when I need it, it's there. I use it most often on slippery, wet boat ramps. Obviously, I don't have the weight of a fiver in the bed on boat ramps. I also use it on wet grassy slopes with the fiver. On the very rare occasions when I am in snow, I am happy to have a 4x4.
