Daniel97
10 years agoExplorer
f250 or f350?
After for lurking around for a while, I may have decided to pull the trigger. I am looking to buy a 2016 Dutchmen Denali 307RLS. I can tow with the F250 without being over weight (on the higher side, ...
Timay wrote:valhalla360 wrote:Until it doesn't! We pulled down into a farm lane and off in a field for a family reunion, pulling a 26' travel trailer. Going out on the dirt farm lane that went uphill, the dirt would let the tires spin as the traction was gone from the angle of attack. Tried it about two times then put it in 4WD and drove right out. Many more similar stories, mine and others.
If it's a single rear wheel F350, I would go for that.
Unless you do a lot of off roading (for which an F250 or F350 is a horrible option anyway), not much benefit in going 4x4.Realistically, a 4x2 with limited slip and a 5th wheel on the back will have a ton of traction.
4WD for me!
Tim
