kennethwooster
Apr 03, 2014Explorer
I picked up a 2014 F350 with the prep packagel I'm pulling a 32' Cameo which I know is heavy. I was pulling it with a F250, using air bags, as it was overloaded. I've estimated the Cameo at 13000+ plus. Yes it squats some, more then I figured, but pulls perfect. The overloads seem to be barely touching the pads. This truck is designed to pull over 22,000 lbs. I should have a thousand plus pounds left. I do need to weight the rig.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
