nremtp143
Apr 03, 2014Explorer
ependydad wrote:
Thanks for posting this and for the responders. I've always been surprised how much my 3500 DRW Ram squats with 2,500 lbs. of pin weight. My headlights aren't pointing at the sky and my front axle weight doesn't change. Glad to see this is fairly normal.
I for one am glad they squat a little. If not, can you imagine how rough of a ride and towing experience would be? As long as the rigs are not sagging in the rear, or a reverse rake, they should all be fine. I just like the bags to help stabilize things a bit. It doesn't hurt that I can adjust it back to the factory rake. My truck sits perfectly level with only the 5 pound minimum pressure in the bags with 3100 pounds on the hitch.
Monty
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
