Dakota98
Jun 28, 2015Explorer
The fans are for air circulation & not necessarily to blow air onto the fins.
I have a Dometic 2652 & my fan works great.
This was less than $20
I ran the fan hot wire down through the drain tube & to the 12 volt connection on the back of the frig. The fan unit, once attached to the fins is self grounding.
Did you purchase a fan setup for this purpose, or just one you found somewhere? Is it self grounding ? Where are you drawing power from ? Is the hot lead fused ?
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
