Vulcan_Rider
Jun 28, 2015Explorer
sfpcservice wrote:
I'll try that. Not sure why it would make a difference. The off the shelf fans clearly clip right into the fins...
Let's try this again.
Was there a problem with the operation of the fridge in it's stock configuration? Probably not.
The fins are designed and sized to cool the fridge part the proper amount relative to the freezer AND the sensor is positioned to detect the temperature at an engineered point to cut off or slow down the cooling.
YOU DON'T NEED EXTRA FANS.
As your experience plainly points out, the extra air flow screws up the designed operation.....as does moving the sensor.
The ONLY time it will help anything is on the initial cool down......maybe.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
