B.O. Plenty wrote:
Before you spend a lot of money. Open up the tops of the jacks and lube everything up well. You might be surprised how this helps.
B.O.
Definitely. Just went through that. After mine sat for many months, it would not lift itself without blowing the fuse. And I had lubed the bevel gears as part of normal maintenance. What really needed lube was the leadscrews, and I had to drill access holes in the legs to get lube where it was needed. Once I had lubed the leadscrews and run them in/out, it is like new again.
