We just had the landing gear motor assembly come loose shearing off 3 of 4 mounting bolts on our new 5th wheel toy hauler. Covered under warranty, but we have to wait a week for Lippert to send the parts (new motor and gear reduction assembly).
Preferred not to leave our unit at the dealer while waiting for the parts, so I decided to manually crank the landing gear to hook-up. Of course, wouldn't you know, in their infinite wisdom, the factory didn't take the time to properly line up the landing gear shaft with the exterior access hole. I had to use a hammer to force the crank onto the landing gear shaft at a crazy angle. I suppose I should be thankful I was at least able to do that.
Anywhoser, retracting wasn't too bad; however, extracting was so difficult it consisted of pushing up the crank 1/2 turn, then changing body position to pull down 1/2 turn. Took about 20 turns of the crank to move the landing gear about an inch.
My arms are killing me this morning :(
