captjohn57
Jun 12, 2012Explorer
I've had my '13 3905 for almost 6 weeks and 3 trips so far. I think the build quality and layout is much better than my '08 Fuzion. Yeah, I'm having a minor problem with my main slide and the rollers under the rear part of the couch marked the floor before I solved the problem. I fixed the drawers not staying closed and the extra legs under were too long for the garage bottom bunk. I pumped the hubs full of grease, they had none, and checked the bearing preload and brake adj. Same problems with my Fuzion. The Voltage floors are more solid, walls apparently have an inner skin of sheet metal that I found adding hooks to bath and bed room closets, screen doors are MUCH better made, fiberglass under the fifth wheel behind the pin instead of flimsy plastic, bla bla bla...
They're trailers and all will have problems. My dealer is hard to get moving but when I bring it to them it's done in a day or so. I get them to order parts before hand when ever possible (used them for my Fuzion too).
So far I'm very satisfied with my Voltage and I hope everyone gets the bugs worked out = )
Maybe see you on the road!
Capt. John
Capt. John
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
