captjohn57
Dec 16, 2013Explorer
soonernation wrote:
How do you tie that car down to keep if from moving around? Do you use the standard D rings that are installed in the floor of the garage?
The standard d rings aren't much and just screwed to the cross members.
I thru bolted 4 - 6000# flush mount swivel rings at the 4 corners of the garage. I was able to get at least 2 of the 4 bolts of the rings in the trailer main frame. I use wrecker "J" hooks to hook 4 - 3600# ratchet straps to the frame of the car in an "X" pattern. By holding the frame, the car barely moves at all :B
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
