Itching2go
Oct 20, 2017Explorer II
...and even better than a 10 gallon tank is Atwood's unit that has a 10 gallon tank with a mixer valve on the output side. The water in the tank is heated to a much higher temperature than is safe for direct use, but the mixer valve continuously adds cold water on the output side to keep the water hot, but not any hotter than the output of a normal hot water heater (120 degrees, I believe). The end result is the equivalent of a 16 gallon hot water tank. We have one that is gas/electric, and have yet to run out of hot water. Good product, and I believe is an available option from Jayco.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
