I installed my hitch myself, It was square. problem is my quick remove pins don't want to come out of the rails. what did I do wrong? I put the metal lugs in between the hat channels of the bed to kee...
Your install is fine. You really don't want the pins to easily slide out. It keeps someone from pulling the pins when you're away from the truck. I use to have to get a screw driver and hammer to tap mine out. There's nothing wrong with yours. Better left alone then to be loosening and re-tightening things.....
