stickdog wrote:
I was told if your brakes are adjusted properly you should set the gain at 50% in a safe area drive to 20mph and stomp on the pedal. If your trailer brakes lock reduce gain, if not increase gain and repeat and continue to increase the gain till they lock at 20mph. You then want to back off to the previous gain where they didn't lock at 20mph. As the brakes wear you will need to either adjust the gain or the brakes.
You don't really do that do you?. The correct way is to pull the brake LEVER on the controler. Not stomp the pedal.
