Rwake901's avatar
Rwake901
Fifth wheel brakes
This is my first 5th wheel and I have a question about the brakes. The brakes on the 5th wheel do work but should I be able to lock up the brakes with the gain on the brake unit adjusted up all the way or is it normal not to be able to? Thanks
  • At low speed, yes but not at high speed.
    You do feel a strong pull even at highway speed if you pull the lever.
  • I can lock up my empty car trailer but not my 5er. Maybe mine need adjustment.
  • I am no guru.
    I can tell you that I have owned half a dozen trailer brake controllers and about as many trailers. On the every one of them I could lock up the trailer brakes if I turned the gain up to high.
