kzspree320
Jul 15, 2017Explorer
Stewart123 wrote:Road Phantom wrote:
We have a Keystone Cougar Xlite 5th wheel with the rear kitchen. I'm not sure if it's up or down in class from the Laredo, but we have had very little trouble with it. The downside is that our Ram 2500 is a little high for the trailer. So far we pulled it to Calif from Pa and then down to TX to Fl and back to Pa.
We wintered in TX for three years in it. The fridge went out but I can't fault Keystone for an aftermarket product that's out of warranty.
Interestingly, we tow with a 2500 5.7 Hemi, get about 11 mpg flat hwy doing 60 and so will stick with the gasser when we eventually trade to a new truck. If you will be over a 9000 lbs 5th wheel get the diesel. Otherwise, the Hemi is a strong alternative and won't burn a hole in your pocket. We owned 9 trailers and 5th wheels since '85 and feel this has been one of our best trailers overall.
Great information! My husband is leaning towards the diesel 2500 series but the fifth wheel, unloaded, would be in the 8300 lb range most likely.
I'll be the first to say diesels excell when towing heavy, but you seriously don't NEED diesel to tow under 10K lbs. A lot of people towing with gassers don't pay any attention to the rear axle ratio when truck buying. They just buy what's on the lot. My 2016 Ram does a great job towing my 12,000-12,500 lb high profile fifth wheel with the 6.4 hemi. It has a 4.10 rear axle and is rated to tow 15,650 lbs. I live in flat Louisiana but have towed Tennessee and Kentucky with this combo (did great and could go 65 everywhere I went) and will soon head off to Colorado.
I get 8 mpg towing this fiver with the 6.4 gasser and I got 11 mpg towing the same fiver with my 2015 Ram with Cummins diesel. If most of your towing is at elevations above 5,000 feet with lots of steep and long grades, I can certainly see getting a diesel at around 10K lbs. If most of your towing is in the eastern states, with occasional trips west every year or so, then a diesel is certainly a luxury and not a necessity. It's your money to spend any way you like. I just think it's bad advice for anyone to say you NEED a diesel at 10K lbs to someone located in flat Florida.
About Fifth Wheel Group
