bpounds wrote:
Dtank wrote:
BTW - the idea about adding a ball under the 5th is rediculous..:R
Might be that you lack imagination. That is a better point to lift from, than a pin 4' off the ground.
A trailer ball would not be the way to do it however.
The "lifting" is *not* the problem...:R
Moving it around when lifted *IS* the problem.
*If* you have a paved surface (not grass), that's level and flat
(no curbs to "ramp up") there are several options (like Power Caster) that work well - all of which use the pin.
Soooooo if somebody knows of one, I'll join the OP and put it to use.
