sljkansas
Jan 09, 2015Explorer
The B&W has a under bed mounting plate that is mounted to the frame. there is a hole drilled in the bed floor that mates up with the locking mechanism. you pull a rod that is in the wheel then install the base for the Companion in the hole then release the locking rod.
Install the Companion on the base, and you are ready to go.
Go to Turnoverball.com to check it out. No rails, easy to remove and you have your flat floor back.
Once you have or used a B&W you'll wonder why it wasn't your first choice.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 18, 2026
