skinnymeExplorerOct 06, 2019Fifth Wheel Hitch HeigthNew to Fifth Wheels. What should be the approximate distance between the top of the truck bed and the top of the fifth wheel hitch. I have 4". Will this be enough? Thanks in advance.
romoreExplorer IIOct 06, 2019Is your trailer level? Four inches is really not enough, you may have to raise the hitch making it a bit nose high which is not ideal.
Related ContentHitch HeigthPin HeigthWheel bearing repacking5th Wheel took out rear windowFifth Wheel Weight
