MN_Ben
Feb 08, 2022Explorer
Instead of reaming out the hole, I would suggest...
Remove the head from the rails. Loosen up the bed rails. Don't remove the nuts from the bolts, just loosen them enough where they may adjust when you put the head and pins back in.
Once you loosened up the nuts and blots, place the head back onto the rails. Now put all 4 pins into their holes. All 4 pins should be able to slip into their position easier. If they don't, tap on the rail that needs adjustment until the pins go in correctly.
After you get the pins to go in and out to your liking, leave the head on with the pins in place and tighten down the rails. Be careful not to over tighten the bolts to stress them. There is probably a torque setting you should use. I suggest contacting the company for this torque setting. If not available, reference a torque guide for the size and grade of bolt you are using.
Test the pins so see if they work better. Repeat if necessary.
I used this method and installing and removing my hitch head from the rails was so much easier and less stressful.
Good Luck, and let us know if this worked for you.
Ben
Ben
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
