humblerb
Feb 13, 2022Explorer
cummins2014 wrote:Cummins12V98 wrote:laknox wrote:
Instead of band-aiding this, since you have the pucks, why not sell the current Patriot and replace it with a Patriot OEM? Either used or new. Most B&W hitches in good condition sell for 50%, or more, of MSRP.
Lyle
Not sure if this is the same person but selling the existing and buying the puck slider was mentioned.
B&W's are easy to sell.
Like a lot of folks ,they don't know they can get the frame adapter ,and stay with their rail mount hitch . I did ,and the only drawback to it ,it's one more thing to deal with if wanting to remove. Mine hasn't been removed in a couple years now , no need . The ideal thing is it can be removed for the ones that want a clean bed .
The OP asked about selling hitch awhile back, and the frame adapter was suggested , it's unfortunate that he has a hitch that was not built correctly.
Appreciate all your help.
If it helps anyone else, I wanted a way to remove and install my hitch easily, so I can have my bed back when not towing. I can't back my truck far enough in to my shop to clear the raised door (in order to use a winch from the ceiling). My shop is a steel frame and I have a steel header on the door. I installed an eye bolt in the header. Bought a Harbor Freight chain fall (around $60).
Now, I back under the chain fall, lift the base and drive out from under it. I have a rolling cabinet that I lower it on to and move it to storage.
I even use the chain fall on the puck adapter the same way, except when I drive out from under it, I lift one side and unhook from the chain fall and lower that edge to the ground. Then I put it on a dolly and move it to storage. Much, much easier handling all this for a 64 year-old desk jockey.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
